sealed or ported fiberglass wheel well enclosure?
  • 2
HI guys, I hope everyone its enjoying the summer. Im finally done with the fiberglass wheel well enclosure. The main point with this enclosure is to save space.
The fiberglass shell its done and I added good bracing. Now Im not sure if I want to just leave it sealed or actually find a way to add a flared port to it, I like hip hop, reggaeton and other kind of music but listen most to those listed
The problem adding a flared port is that the wheel well shape of a 1999 civic hatchback its very irregular where the first halve of the box its smaller than the other part but its about 1.60 cubic feet with bracing.
I will use a JL 12w0v3 and a ppi 1000. I know the ppi have a lot more power than I need for the sub but in the future I want to upgrade to a IDQ 12 or maybe a JL 12 w3v3. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
but for now Im a little under the 1.75 cubic feet for the JL w0v3 and a little more than the recommended sealed air space for the sub.
I already calculated the port lenght for the fiberglass box and doing a 3 inch diameter port tuned at 33 HZ I need 7.80 inchess of port lenght but the problem is that since the port should go faced with the sub since the rest of the enclosure its against the wheel well then I have to use a 90 degree pvc piece due that the height of the enclosure its really not much for 7.80 inches
with that said do you guys recommend me to
1- use the 90 degree piece and go ported !
2- go with a 2 inch diameter port and then only need 3.4 inches of port length!
3- screw all the flared ports and go sealed!
You can add a port and still have a nice sound. I calculated it to be a 9" port with 3" diameter at 1.5 cubes. = 33hz, taking sub displacement into account. That should be ok.
I scrolled thru there trying to find TS specs and must have missed them or they weren't displaying. Anyway, looks like 2cuft tuned to ~35hz was a...
9
For what it’s worth… I picked up a mti stage 4 or 5 for around 900.00. Loaded with jl tw3 it’s was 1995.00. Which is a good 1k off what I would...
6
Assuming the taget curve is the same they will sound very similar. 2nd and 3rd order harmonics might be different but are offer hard to even hear...
😂😂 I actually have a CNC at my shop (I make drone parts for a living). It’s just that I got intimidated by all the tuning (equipment I don’t...
18
3K
I dont think this forum is letting that link work. It keeps changing it to a link to this forum. Try this. Just change the dot...
10
yusme
yusme
United States
subzero
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
