Set up
  • 2
6x8 is the stock size in most Ford trucks. Don't bother with the rears. Having mids and highs coming from behind you is not great in general and worse with the factory locations in Ford trucks.
2 way with the mid in the stock location and tweeter up high worked OK in a couple 250s I've done. Kicker makes some serviceable ones if you're on a budget the JBL club is a good bit nicer but more money.
Crutchfield sells plug and play adapters so that you won't have to cut the factory plugs in the doors (they're only a couple bucks) and you can get Q-forms kickpanels for many of the Ford trucks which I would recommend if you aren't afraid to spend the money and need the extra output from an extra set of components.
6
438
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
8
809
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
871
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Send me all the items. Once I receive them, I will verify everything in your classifieds. If someone buys them, I will ship out. You would just...
vladtheinhaler
CarAudio.com Newbie
vladtheinhaler
ontario
hispls
HandsomeSteve
    Jun 5, 2024
HandsomeSteve
    Jun 5, 2024
