settings and tweaking help needed
  • 1
bigchevyboy
ok I need some help with what should the 0 180 phase switch on my amp be set to as well as the other nob with the #'s on it. its a RFt3001db and on my deck help is needed setting subwoofer. it also has that 0 180 setting and what I guess would be the sub frequency. I can hook it up but I can't tune it worth a ****. sorry if I sound stupid for I am a novice stereo tech. thank you
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
6
755
The intention of the eq is to create a flat curve if you have peaks and nulls. If you are competing for sq, try to get the sound as flat as...
5
693
You are going to need to beef up your sub stage in that vehicle to get that kind of bass response. A good pair of American Bass XFL 10s or 12s or...
4
bigchevyboy
bigchevyboy
richtown va
bigchevyboy
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
