Shielded RCA's
  • 2
JJ30
Hello everyone! My stereo was picking up heavy amounts of engine noise/whine, I moved the ground location for my headunit (from harness to chassis) and my amplifier ground as well. Neither helped. Then a thought struck me; maybe my $1 RCA's might be picking up this noise!//content.invisioncic.com/y282845/emoticons/redface.gif.62fdbfe1a101588a808c4cff71bcb942.gif I held my headunit away from the dash, and moved the RCA's away as well, and the noise dissapeared. I glanced inside my dash and 3 sets of 3 wires going to the 3 12v power supplies on the dash were sitting right there!! I moved my RCA's close to these wires and the noise increased, I moved them away and the noise went away. So now that I've told my story, can someone please tell me which specific RCA cable can protect against power radiation when the RCA is practically sitting directly on top of a a jumble of 10 gauge wires running 12v through them? Thank you!!
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif Also, under $30 would be awesome and preferably 3ft or 20ft
Thanks for your input. I'm trying to make sure I do the wiring correctly during the restoration of my 1971 Maserati ghibli SS.
4
No make or model number on it? Do you have an exact picture of the rear and all its glory?
8
727
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
711
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
616
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
6
765
JJ30
JJ30
Hillsboro, OR
basshead7890
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
