Shok II Amplifier with Toolmaker dual inputs
Goindef154
Nothing
5,477
Phoenix, AZ
Shok II Amplifier
I'd give this a 7-7.5/10 cosmetically but 10/10 functionality. It's beena great amplifier for the last 4 years and was still pushing strong when I uninstalled it.
Comes with everything you see, Wires are about a foot long each.
Digital linkable & strappable monoblock amplifier
Dual MOSFET PWN Power Supply
Stable into no lower than 1 ohm mono load
Stable into no lower than 2ohm load when strapped
24 dB/Oct variable low pass filter
24 dB/Oct variable subsonic filter 4 way protection circuit (Thermal, Voltage, Speaker short and DC)
Wired remote control included
Strappable Connection: Master output/Input slave
0awg power & ground inputs
Output Power (RMS)12v Power
4ohm 500w
2ohm 1000w
1ohm 2000w
Strapped Output (RMS) 12v Power
2ohm 4000w
Frequency Response: 15hz – 270hz Damping factor: 200
Input Sensitivity: 6v-0.2v
Low Pass Filter: 35hz – 250hz
Subsonic Filter: 10hz – 50hz
Bass Boost: 0-9db
Phase Shift: 0 – 180°
Fuse Rating: 250A (single) 2x250A (strapped)
Dimensions: 235mm(H) x 62mm(D) x 520mm(L)
$390 Shipped
Google and Ebay are your friends. Froma quick search and providing these are like new, $2- $400 for the subs and $2- $400 for the amplifiers...
The CT's are nice, That Sundown is a a frik'n beast!
774
782
Ok, i will go on this option. Thanks a lot bro for the help, i really appreciate again, Cheers
849
Goindef154
Nothing
Goindef154
Phoenix, AZ
Goindef154
    May 22, 2024
    May 22, 2024
