Shortage in speakers.
  • 4
jg77
25
Florida
I have had my aftermarket stereo and door speakers for a couple of months and haven't had any problems until now. I was moving some stuff today and put some stuff in my trunk and my speakers started going in and out. Their is wiring in my trunk but I'm not sure what is to. All my speakers have static and aren't playing. They do play for a little bit if I go around a curve or something. I'm not sure if I messed up something in the trunk or if the something else is the problem. Any help is appreciated. Thanks.
check to see that you didnt pull any wires out of the amp one could be out and when you turn it hits the terminal and closes the loop... i would definately look into it all very closely your power wire may be loose and this could cause serious issues if you dont have it properly fused
If the JBLs have tweeters built in, disconnect two of the tweeters and the 4 Ohm tweeters will be their replacement. Then connect one combo on the...
190
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
182
In the past 10/15 years. I feel like the best sounding/performing speakers Ive ever heard to date were some Hertz MLK & Mille series running off...
360
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
7
500
jg77
jg77
Florida
rosshimself13
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
