Should a Voice Coil Look like This
matt_martin87
OG
My 15 inch TC Sounds LMS-R showed up at my door a few minutes ago. While unboxing I took a few snapshots. Everything was fine until I saw the voice coil. Have a look.
This doesn't look right at all. Nothing is symmetrical and I doubt it would fit into the gap seamlessly. It actually looks like a 5 year old assembled the coil.
Am I way off here or is this just as bad as it looks?
I thought the LMS coils were designed differently, to increase linearity as the coil is moving in the gap. That does look sloppy though.
Doesnt matter what it looks like. Its designed like this for a reason, and you wouldnt see it anyway.
It's super difficult to wind an LMS coil -- inevitably they aren't super pretty coils... but don't worry, they are supposed to look like that.
Yessir. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Allows the BL to remain semi-constant at higher excursion levels.
The CT's are nice, That Sundown is a a frik'n beast!
714
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
630
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
717
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
matt_martin87
OG
matt_martin87
Beatrice, NE
-01limited-
    May 18, 2024
    May 16, 2024
