Should I put my compressor and drivers on its own channel also I have 3 amps how should I put my mids and tweeters
  • 3
CHRISLOISELLE84
CarAudio.com Newbie
4
PA
Hey everyone, please excuse my ignorance. So I have a few questions on my build and was hoping someone would help me out and point me in the right direction.
First off let me explain my build let everyone know what I have. Knuconcepts 1/0 OFC wire did big 3. Same wire used to feed power to Knuconcepts fused distribution block. All wire is Knuconcepts OFC wire. Boss 8 farad cap. Boss AR4000D mono Amp. With Knuconcepts Karma Kable twisted 8 gauge OFC wired 2 15" Gravity war zone DVC subs. Wired to 1 ohm in a slot port custom enclosure. 2 1200 watt 4 channel amps 8-DS18 PRO-FU10.4 10" MIDS.- 10"/2- DS18 PRO-M8.2NEO 8" MIDS/4-DS18 PRO-NEO6R 6.5" MIDS. 4 DS18 TW820 super tweeters and 2 DS18 PRO-DR250 compression driver horns.
My question is how should I wire them to what channels should I wire any of them together I'm waiting for an electronic crossover and equalizer 2 come in
So what I'm asking is should I have my tweeters and compression drivers on its own amp by adding an one or should I have my tweeters and compression drivers hooked up to some of my mids with a passive crossover. What should my amps be set to I'm currently only using the high pass filter should everything be on the high pass filter. Should I have any mids on full/lp. Again excuse my ignorance but I really wanna learn this. How so I set the. High pass filter and to what for mids and highs
8-DS18 PRO-FU10.4 10" Mids
2- DS18 PRO-M8.2NEO 8" Mids
4-DS18 PRO-NEO6R 6.5" Mids
4 DS18 TW820 super Tweeters
2 DS18 PRO-DR250 Horns
2 4 channel amps.
Are all these going in doors or a stunt wall?
You are going to want a crossover for sure.
The CT's are nice, That Sundown is a a frik'n beast!
7
716
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
632
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
721
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
8
CHRISLOISELLE84
CarAudio.com Newbie
CHRISLOISELLE84
PA
YourNameHere
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
