Should I run 1 or 2 subs?
  • 1
c_hayhurst
Hi!
As a daily driver, I currently have 2 TC9 12" subs (2-Ohm DVC) rated at 800W RMS each in a ported enclosure. I used to run them off one Infinity 611a at 750Wx1 RMS at 2 Ohms. Now, I run them off a Hifonics BXi2008D, rated at 1600W at 2 Ohms. The Infinity is definitely a better-sounding amp and SPL is pretty close to the Hifonics. I am considering building a new box for just one sub and having it run off my Infinity.
Which would you recommend:
a) keep the current setup of 2 subs and the Hifonics
b) keep the 2 subs and run the Infinity again
c) drop to 1 sub and run it off the Hifonics
d) drop to one sub and run it off the Infinity
Suggestions?
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
The CT's are nice, That Sundown is a a frik'n beast!
7
938
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
767
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
894
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
8
c_hayhurst
c_hayhurst
Columbus, Ohio
c_hayhurst
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
