significant upgrade?
I would go with the Fi BL's instead of BTL's because BTL's can only produce bass for 30 minutes. BLs can for an hour.
Haha ^^^^^ very informational....thank you DR //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
egg
I thought about it and im just going to stick with the Z's because not that many people run them, and i see some really good numbers produced by them..
what the main difference between the Z and the nightshades other power handling?
The main difference really is power handling between the two... once the Z v.2 is equipped with a copper coil it's bottom end comes right up in line with the NS v.2
The NS does have more linear x-max as well -- but both have more than ample x-max.
Hello, I have a Peugeot 207 SE 2007 and would like to upgrade its existing car stereo. It’s a single cd fm/am radio and I would like to get...
That's not an amplifier designed for subwoofer use, it's a 4 channel designed for you primary speakers. Small $75 investment to get you where you...
642
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
768
Thought I would update this thread… Couldn’t login over the weekend for some reason. Finally got the Kenwood installed last Friday… Had a little...
32
Are you planning on upgrading the alternator and add extra batteries?
853
Lschevelle
Lschevelle
LA.
sundownz
Decebal
    Jun 10, 2024
