singer 300 amp alt.
  • 2
splwj47
used for about 8 months. works beautifully. never had an issue with it. has adjustable voltage from 12v-15.3 volts.
fits 99-04 v8 jeep grand Cherokee. may work with 4.7L v8 dodge motors as well.
half shipping.
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
534
This Is a NIB amplifier, one of two that I was to use. Decided to go class A/B on the front mids and tweets and just purchased a Helix B FOUR...
Good thing its under warranty and that you have contacted A.Control about the issue so it has been documented. It will help speed up the return...
6
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
splwj47
splwj47
Great White North
splwj47
Decebal
    Jun 10, 2024
