Single 12" (D2) to run on 1700 daily
  • 4
rtillaree
F***, Strong
4,167
Orlando
Looking for more of an SQL driver, if possible. Going to be running on consistent 1700 daily @ 1ohm in 2.25cu @ 33hz. Don't care if it's a frankenwoofer or an OEM. I only care if it works well and doesn't have any glaring cosmetic issues that will worsen. Ideally I find an IDMax, Sundown SA and Z series. My budget is definitely under $250 (depending) shipped to 32771.
Word. Was built for a Flatlyne, did pretty well in there too. Given the size, I was thinking the Z series might be a good fit but.
No prob. 2.5 is the largest for a zv4 if that's what you were thinking you can add 45s in th corners to make it smaller. But I don't think you'll get it down to 2.5 either. What you might consider is a sub that takes a big box 2.0-2.5 that takes more power to. But you'll need to up your budget a bit
I just relaized that I typed 3.25 and not 2.25cu. btw. I was like "bruv, chill"....If a solid sub is offered I'll consider upping for sure. I figured I could net a nice used driver in this range for my application. I've seen them come and go so, I'll wait it out, not foaming just yet.
I've got a ZV.4 12" I'm willing to part with...d2 barely used...would have to up the budget though.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
676
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
4
rtillaree
F***, Strong
rtillaree
Orlando
C1500martin
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
