Single Cab truck Sub Suggestions - LIMITED SPACE
  • 3
hotbox
16
TX
Quick run down:
Single Cab truck, custom box for two 10" subs sealed.
Amp Audiopipe ASPM1500 1500w
Limited space: The last subs had a 5" inch mounting depth which were the limit I think for the box.
Budget: $150-200 for two subs
Going for mostly sound quality, but wouldn't might some loudness.
I just want something better than what I had before:
Here are my last subs 10" Subwoofer - CS-WG1000 - Features
Any suggestions?
I know this isn't exactly what you're going for, but Bill Fitzmaurice Designs has their new single cab Auto Tuba design. Its only an 8 inch sub, but can be accommodated for 10s. Not the loudest, but has good SQ and for the price you can't complain about the loudness. The entire build, wood, glue, sub, etc. (minus the amp) would be well under $100 for a single 8 build. The 8" sub he designs for are $30-$90 and the 10" he designs for is $70. So take that plus the price of wood and $15 for the plans.
I used to run his normal Auto Tuba design on that $30 8" and it pounds for what it is. Also has a very good frequency response.
I would add an ANL Fuse @the amplifier supply with its recommended 100 ANL fuse, and Keep the 120-150 @the Battery...
6
Hello, What amps should I use for this: 2xFocal Auditor Sub 12 Slim Focal Expert PS165v1 Can Focal FPX 5.1200 work or is too much?
Well the setup I mentioned cost around 1,000 USD in my country and an extra 500 USD for the DPS. HU? The car display? I plan to stay with original
8
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
442
hotbox
hotbox
TX
fatboytyler
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
