single DC audio level 3 15 box?
  • 4
I would add an ANL Fuse @the amplifier supply with its recommended 100 ANL fuse, and Keep the 120-150 @the Battery...
6
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
491
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
769
dylan117
dylan117
Louisville,KY
Foulplay
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
