Single Din HU reccomendation for Evo Please!($350 budget)
pheonix991
Getting an Evo within the next couple of months, the Evo IX only has a single din, and I'm not doing an AC relocation mod just to get another sub par $550 double din. I'm looking for specifically an aux input, high voltage aux for 4 channel amp and sub, usb input, ipod input is nice, and not ugly, that is about it. I have a $350ish budget.
Yes I searched.
Thanks for the help!
The alpine website didn't say anything about being able to read from a usb drive. Do I also have to buy that cable to be able to use an ipod? Or is there a usb cable I need? I don't have an ipod, so, I've been putting music on my usb drive and reading from that.
not to thread jack, but will going from 2.5-3V preamp to 5 V preamp make a noticeable difference in sound?
I had a AQ1200D on my SDC2.510 just like in your case and noticed quite a difference going from 1.8v preouts to 5v...so absolutely.
So what if I kept my headunit right now (2.5-3V) and used a Equalizer (7V max)? Wuold that eliminate the need of a HU with more preamp voltage?
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
762
Check each speaker for shorts. A pinched wire grounding out or a individual blown speaker can sometimes make the internal amp go into protection.
7
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
485
pheonix991
pheonix991
Malmstrom AFB, MT
nateberrier
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
