Single punch 2 sub
  • 4
The amp will have no effect on how well your sub reproduces low frequencies //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Also, welcome to the forum.
The amp will only do it's job to a certain point. If you want some nice low frequencies you'll need a custom ported box tuned low, which I doubt that is.
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
4
948
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
486
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
766
TeggyBoy
TeggyBoy
Dover, DE
09civic
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
