Single Xfl on an AB ph4000?
  • 3
Lowlacs
I have a solox now on an AmericanBass Phantom4000(2Krms?) but just cannot give it the enclosure it needs considering im in a single cab super duty now. Ive ran this amp on a pair of the xfls but Id swear they were begging for more. So Im now considerin giving a single xfl dual2 3cubes and all of the ph amp. Im on a short budget, due to the season, so please no (other)amp suggestions as this is what I have and can afford.
So do u guys think the Phantom amp will supply clean enough signal to overpower the Xfl sub without issues? Also do u think the Xfl can take it? Id hate to launch or burn a coil. I have a Deka g31 going in 2ft from the amp along with an interstate Megatron under the hood so I dont think power supply will be a problem. Also will be using a dmm to set gain until I can find a DD1 or an Oscope. I suppose I could always gain down if need be but....
2k your reaching to the top but as long your not a idiot on the volume knob you'd be great.....
Well, My drinkin days are over so I dont have nearly as many idiot moments anymore. So gain Down abit and with some common sense this should be a decent combo.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
675
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
4
Lowlacs
Lowlacs
Live Oak Fl. 32060
Lowlacs
