Skar 3500
  • 2
350zkid
1. Product:
Skar 3500
2. Specs:
Class D Digital Monoblock Amplifier
Compact & Versatile Design
Linkable / Strappable
4 Way Protection Circuitry : Thermal, Voltage, Speaker, DC
RMS Power @ 1 Ohm : 3,519 Watts x 1 Channel (14.4v)
RMS Power @ 2 Ohms : 2,066 Watts x 1 Channel (14.4v)
RMS Power @ 4 Ohms : 1,178 Watts x 1 Channel (14.4v)
RMS Power @ 1 Ohm : 4,083 Watts x 1 Channel (16v)
RMS Power @ 1 Ohm : 5,102 Watts x 1 Channel (18v)
Frequency Response : 20~270Hz
Input Sensitivity : 6V~0.2V
Signal to Noise Ratio : 95dB
Damping Factor : 200
Low Pass Filter : 35Hz~250hz
Subsonic Filter : 10Hz~50Hz
Bass Boost : 0dB~9dB
Phase Shift : 0~180 Degrees
1/0 Gauge Power and Ground Terminals
Working Voltage : 8.5V~18V
Remote Gain Knob Included
Line Out RCA Connection
Dimensions : 540mm (Length) x 241mm (Width) x 64.5mm (Height)
3. Description/Condition:
BNIB
4. Price: :
$600 NO TRADES. Need $$$
I can work something out knowing that's a bit of cash to throw at one time.
5. Pictures:
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
558
934
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
350zkid
350zkid
St. Petersburg, FL
350zkid
