SKAR Audio SK-Series Class D Monoblock Amplifier Line
  • 5
SkarAudio
Florida
The SK Amplifier production run finally finished, and we are very pleased with the quality of the work as well as the final products!
They are already in transit to our warehouse, and are expected at the end of January to start shipping!
Note - The SK-4500.1 is finished however we are not stocking them until end of March(ish). We will notify you of when the pre-order starts for those.
The Pre-order IS still open for the SK-800.1 and SK-1500.1, if interested just E-mail or PM us!
SKAR Audio SK-1500.1
RMS Power @ 4 Ohms (14.4V) : 500W x 1
RMS Power @ 2 Ohms (14.4V) : 930W x 1
RMS Power @ 1 Ohms (14.4V) : 1680W x 1
RMS Power @ 1 Ohm (16V) : 1900W x 1
Strapable : Yes
Signal to noise Ratio : 85
Damping Factor : 150
Low Pass Filter : 35~250
Subsonic Filter : 10~50
Master/Slave : Yes
Operating Voltage : 8.5V-16V
Efficiency @ 4 Ohms :
Bass Boost @ 45 Hz : 0~9
Frequency Response : 15-270Hz
Remote Level Control : Yes
Power & Protections LED Indicators
Wire Input : 1/0 Gauge
Dimensions : 350mm x 241mm x 64.5mm (L x W x H)
SKAR Audio SK-800.1
RMS Power @ 4 Ohms (14.4V) : 340W x 1
RMS Power @ 2 Ohms (14.4V) : 570W x 1
RMS Power @ 1 Ohms (14.4V) : 820W x 1
RMS Power @ 1 Ohm (16V) : 1000W x 1
Strapable : Yes
Master/Slave : Yes
Wire Input : 4 Gauge
Dimensions : 250mm x 241mm x 64.5mm (L x W x H)
*Please note that the power ratings are "Sheet Specs" and these amplifiers actually produce more, and are rated @ 12V. I will post clamp results immediately now that we have the finished versions.
SkarAudio
SkarAudio
Florida
NT_Hardcore
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
