Skar rp 2500.1
  • 2
Removed rf p1000.2 a/b on 2 cvr 12s for skar rp2500.1, battery under rear seat so power wire to trunk is under 5 feet. Alternator to battery is factory 2 gauge, battery to amp is 4 gauge with 150amp circuit breaker to subs and 10 gauge to soundstream pn520d which is about 275w rms to kappas 6.5s and 5.25's, am I good with the 4 gauge from battery to amp for the skar?
with it being such a short run it "SHOULD" be ok. I however would suggest to upgrade it to 0ga though, just to be safe
also i think you meant to put Skar RP-2000.1. They dont make a RP-2500. Now if you have the Skar SK-2500 i would upgrade it 0ga asap
My bad it's the rp 2000.1 n I do have about 12 ft of 0/2 welding cable, currently using 4ga welding cable. I don't think I'll ever run the full 2k watts on a full song tho
ok i mean again it should be fine, but i wouldnt run the at full potential with 4ga, if you do i try to run it for 2k i would upgrade
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
417
11
853
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
6
Recoil 2500.1 $179 2500 x 1 @ 1 ohm. Make sure subs are the dual 4 ohm version. If you don't want that much power, get the Recoil red1200.1 for 1...
4
SLAB153
SLAB153
Lafayette, LA
bgowdy
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
