Skar skv2-1500.1d
  • 4
Dolejh
CarAudio.com Newbie
I’m a little confused by the ohms etc. got a skar skv2-1500.1d
4 ohm 500x1
2 ohm 930x1
1 ohm 1700x1
Two skar subs svr-12 dual 4 ohm 800 RMS / 1600 peak
does that mean if I run and wire the amp for 1 ohm I could deliver 850 to each sub?
I think this amp is two small for these speakers - am I right? Should I be running two of these amps or drop down to a lower RMS speaker?
Yes, wire the 2 subs to a 1ohm final load.
They will get 850 each.
That amp is great for those subs.
RMS matches up almost perfectly.
Set your gain correctly and see how your car's voltage holds up when you start to turn it way up.
Do the Big 3, make sure your ground location is a good one, and your wire connection points are rock solid.
The Sakr OFC wire is as good as any other for that price for sure, not talking about their amplifiers. If you have enough, dual 12 gauge runs are...
6
56
11
664
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
6
Recoil 2500.1 $179 2500 x 1 @ 1 ohm. Make sure subs are the dual 4 ohm version. If you don't want that much power, get the Recoil red1200.1 for 1...
4
946
Dolejh
CarAudio.com Newbie
Dolejh
Jacksonville
some dude
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
