Skar VVX motors
Drich79
Omaha
As the title states
Great shape.
Triple .75" slugs, 2.5" coil, 64mm ID, 73mm OD.
$85 Shipped for the pair.
Included
Do you know mounting hole diameter? And over all diameter of the magnet?
the magnet is about 6 3/8" wide and 3 1/2" tall with standard 6 bolt pattern (12 spoke baskets mount right up)
Can you measure the depth of the coil gap? I might interested
From the top plate in it is 2 3/4", From top of pole down it is 3 1/4".
Hope that is what you wanted to know.
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
646
11
974
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
6
Recoil 2500.1 $179 2500 x 1 @ 1 ohm. Make sure subs are the dual 4 ohm version. If you don't want that much power, get the Recoil red1200.1 for 1...
4
Drich79
Drich79
Omaha
tronichead
Decebal
    Jun 10, 2024
