Skar zvx-8 w/t-line
The_Dealer
Macon Ga
Skar Zvx-8 dual 2 ohm 900w rms in a Birch 1/4 wave t-line.
I don't really want to split up the sub and box, shipping isn't too bad on it. The box is 34w/11.25h/12d.
Sub:9/10 Cosmetically. Sub has signs of being mounted, so it will look like it. Heatshrink on the terminal leads rubbed the box while mounting, lead wire isn't damaged.
9/10 functionally. It wasn't my daily so it doesn't have a lot of play on it, around 5 or 6 hrs or less.
$200 shipped
Shipping on me.
was that built to FS of that sub? Trying to figure out where line was tuned to
No, the one before that was and it didn't work so good. This is the 3rd t-line I built for it (6th box in all), I've done a lot of trial and error. It's gonna be hard to find a better box for this sub for daily that will still bust *** in the lanes. But the line length is around 35hz, and the line area is 29.25sqin. (SD is 30.66sqin). When tuned to fs it just didn't work that great.
Sent from my Motorola 2950 Special Edition 3w.
Thanks for the box. Always good to meet another local basshead.
No problem man. I'm just glad to sell it to someone that can appreciate the hard work i put into it, which is the whole reason I re-made the box. I'll get with you this weekend, should have my new setup going by then. I can't remember if I put the OG box and manual in your ride, so if I didn't I'll get that too you.
Just let me know when you head back this way and I'll meet up with you and pick it up.
if you dont mind can i get the complete specs of the box like the port dimensions and all i have the same sub and have been wanting to build a tline for it just not that good with the math
Things happen. It will be a story you can tell him and laugh about when he gets older. Kids around speakers = damaged speakers. I had a yard...
Dave Leib Corey Dean (SPL Audio) https://directronix.net/product/customzvx/
527
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
892
The_Dealer
The_Dealer
Macon Ga
billiemtaylor
Brendon Jenness
    May 8, 2024
    May 8, 2024
