smallish amp help?
  • 5
09civic
sub is one sa 8. wanting to find an amp does that rated and CLEAN or unclipped power. so no audiopipe.
id like to keep it under 200. maybe go with the AQ750 but anyone else got any suggestions? thanks
NOT looking to buy right now btw
Kicker zx400.1 . Very impressive for its size. Does over rated power too(mine did like 490rms). Wish I wouldn't have sold mine. Can get them pretty cheap too.
last time i checked they are not cheap at all...
I may be wrong but I dont think the DTRs are CEA cert
They are slightly overrated by about 100w but considering you can get a 1700w amp for $200 new that puts out clean power it's a pretty good deal. of course, if youre looking for even cleaner power and an underrated amp you want to get the rubi
Two subs, same issue, two LOC's same issue, seems to me that there is an issue upstream. Have you tested the amp disconnected from the signal...
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
318
6
454
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
743
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
542
09civic
09civic
Melbourne, FL
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
