Solutions to Stop Side Window Flex
  • 4
Jeffdachef
Gunz That Turn on Nunz
so my van has rear side windows that just have a basic close and lock mechanism and the pressure is causing them to flop like mad and i'm losing a lot of pressure
I saw someone in a video using suction cups but i can find that video again. Anyone know how to use suction cups to brace the windows to keep it from flopping around or have a link to that particular vid?
currently just have butt loads of foam tape to decouple and fill it in but nothing to stop the actual windows being pushed and pulled by the pressure.
that's a great solution, in one direction
not sure there if there even is a reasonable solution for the other direction anyway lol
If u don't want it to open get a tube of windshield adhesive and put it all on the seal and close the window and let it dry for acouple days
the window does not really make contact with anywhere on the vehicle, just some flimsy weatherstripping so glueing it wont really work.
Remove weather stripping, bolt on a wood or steel frame to the car and then use the window adhesive on that. Itll be like its a solid rear window like the one on my truck.
The link doesn't work for me, (although they never do). I get they might not want to link to a competing website, but if there was ever a reason...
6
I feel like its a bad set(Low tier set) of RCAs myself. I use Stinger Zero Noise and 4000-8000 series without any issues. Dayton makes a nice set...
6
I have read about this, and honestly the installer did nothing wrong. It's the newer vehicles that have the automatic engine stop/start (instead...
Those subsonic frequencies make a difference in how music sounds. Hearing the music and also feeling the subsonics adds a depth to music. You hear...
10
I just learned a couple of days ago that shark fin antennas are powered. Your issue may be related to that. Either the power to the antenna is...
Jeffdachef
Jeffdachef
South Coast Metro, CA
C1500martin
