[SOLVED] XVM279BT Mystery Wire for Subwoofer
  • 1
Ra7eN
CarAudio.com Newbie
HI ALL!!!
Ok, I have a 05 F150, and someone installed a XMV279BT. The wiring was horrible, so stripped it all down and redid it all from scratch.
Now everything works great!
I have another adapter that is for the sub-woofer. It has 2 RCA jacks (red and white) and two blu/white wires attached together. Note: In the picture the wire is hooked up wrong - looks like they tried to hook it up to the antenna.
What wire should I use to get the sub-woofer to work. I have the 1.5k resister I know I need to put inline, however, what is the wire to connect to?
OK, I kept on searching for the answer - found it!
I was able to find an exact wiring diagram for my XVM279BT
APPARENTLY the blue wire acts as BOTH a power antenna (which I do not have) and the amp!
I think that solves it.!
Well, the odd thing is, page 3 of that manual shows the left socket as the rear view input, mute, and steering wheel control. While the right side...
You probably did it already, but post this to 350z specific forums or facebook groups, etc. There's probably someone there that knows.
Ra7eN
CarAudio.com Newbie
Ra7eN
Midwest USA
Ra7eN
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
