Some legit advice for front stage/speakers
now whats the midbass like? the reason i leaned towards the XXX's is for the midbass (or so ive heard)...
any input on that? i'm a little more concerned about the midbass than the loudness of them...but its still a factor, just not as much as the midbass is.
Any input?? Boston Pro60's Vs XXX as far as midbass???
As has been said already, Rainbow Power Line CS, assuming you want to stick with a component 2-way set. Feed them between 300 and 400 watts per side. Worst case scenario, cross them over at 80 instead of 50-60hz to keep them under control at excessive volumes.
Don't be a cheap ass b1tch with your fronstage, after buying a 3kw amp and an 18" XXX. You're not going to find something that will perform adequately next to that XXX for 200-300$, perhaps with the exception of an active DIY setup... and you shouldn't expect anything to, after spending that much on a sub stage. Expect to need 600w+ on your front stage combined across both channels.
Some of it plays well, some not so well lol. New decaf going around of "Break the knob off!" I have been playing and like it.
8
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
542
It also lowers the amps efficiency and raises the current draw.
5
675
i have a 15 already for the lows ita a little over kill for a crew cab but I like it and I was hoping it would sound better and louder than my old...
7
836
BreakingBad
Banned
BreakingBad
pittsburgh
headless
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
