Some modeling help please.
  • 2
The Camry
Hey, I Try.
Hey all. So i'm building a huge fiberglass enclosure out of my entire back quarter panel in my hatch and i just went for it without really trying to figure out total enclosure size. From some VERY rough estimates. We're looking around the 2.0 cuft mark. I ended up getting a SSA Icon 12'' that only calls for around 1.25 cuft sealed. I can certainly cut down or fill in the enclosure once its done to make it smaller. I have quite a bit of power on tap so i did some WINISD modeling and well..i am just not seeing that big of a difference between a volume of 1.25 cuft and 2.0. Keep in mind that im not the best at modeling so maybe i put in a number wrong at some point which is what im thinking may have happened. Can anyone verify this on their own or if they have access to Bass Box, that'd be appreciated as well. Thanks. Pics for reference. QTC= .59 at 1.25, QTC= .53 at 2.0 cuft. Excursion modeled at 2000rms which is the highest rms the manufacturer recommends.
link to the Icon Specs. https://store.soundsolutionsaudio.com/icon-12-1250w-subwoofer-by-ssa/
  • D4 / D2
  • Fs. 30.9 / 29.7 hz
  • Re 8.0 / 4.0 ohms
  • Qms 5.79
  • Qes 0.45 / 0.42
  • Qts 0.42 / 0.39
  • Cms 0.10 mm/N
  • Mms 259.6 / 256.5 gr
  • Bl 21.1 / 21.1 N/A
  • SPL 85.7 / 86.1 dB
  • VAS 37.4 L
  • SD 480cm^2
  • Le 3.7mH
  • Xmax 23mm
  • RMS 1250 watt
attachment.php
attachment.php
attachment.php
HI all - I don't have a windows machine and thus can't use WINISD, so I've been playing with speakerboxlite.com Can someone cross-reference this...
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
217
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
636
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
404
The Camry
Hey, I Try.
The Camry
Western Oregon
YourNameHere
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
