Sony CDX GT-26 No Rear Out / Sub Option in Setup
  • 2
JonnyAlpha
18
UK
Hi;
I purchased a S/H Sony CDX GT26 from eBay as I just needed a head unit with Aux In to replace my old Pioneer DEH-1600R.
There appears to be a problem with the wiring on the back of the unit (dodgy connections) but for now the question I have is regarding connecting this to an external Amp.
I understand that the Amp connects to the RCA Pre Out on the rear of the head unit and according to the user manual here I believe you need to set the audio options to Rear / Sub Out in the setup menu.
The Amp is not connected yet but when scrolling through the setup this option is not available? Is it hidden until an amp is connected?
Many thanks
How many RCA pre outs are there on that unit?
Your partial correct. You will need to shut off the internal amp from the HU to activate the external amp once you plug in the RCA's to the back of the HU.
I have two Head Units and both only have one RCA (L/R) out on the rear. I think they are labelled Rear/Sub Out
I just got a sony cdx-f7715x put in my truck. It’s in demo mode right now cause I don’t have a remote to access the menu. Is there any way I can...
872
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
JonnyAlpha
JonnyAlpha
UK
JonnyAlpha
