Sony XAV-62BT Opinions????
  • 2
08Accord
So I'm in the market for a double-din with bluetooth but I really don't want to spend an arm and a leg. Sonicelectronix has a wicked sale on this unit!!! Should I shoot for it???
Keep in mind, I have JL Comps, Coax and sub and a Cadence 5ch. I'm not completely knowledgeable with all this stuff, so is there anything about this unit that would not work well with the equipment i already have??
Sony has really dropped down in quality.
I would suggest looking at another brand.
Clarion makes quality units for a good price. I prefer Pioneer as they are built solid although the UI sometimes isn't the best
Here is a review I found for the HU you asked about that kinda sums up the problems with Sony
Now here is the laundry list of problems I've experienced: - There are only 2 graphical visualizations during music playback, and they both stink. - User can't upload any pics to use as custom backgrounds. - SensMe function doesn't work AT ALL. I've tried multiple times with my iPod, both with just the regular iPod music, and with a second copy of every single song transferred with Sony's PC software. Simply will not work. - iPod control doesn't work well. I can't shuffle the songs, and it always defaults to the first song of the first album alphabetically in my 1,200 song playlist. - Radio presets jump when I turn off the truck. If I'm listening to station 1 on FM1, it jumps to some random preset on FM3 when the ignition is turned off. - TOUCHscreen is TOUCHy. Usually have to hit it several times for a certain function to register. And even when it does take, there is a long processing pause while the unit catches up with the button push. This product has TONS of potential, but it's almost like Sony didn't even put it through a QC process in the lab. Either that or their inside engineers have simply never played with a high end car audio system.
That looks like it can work for backup cam for sure, thanks
940
Did the articles on issues with this unit not getting audio directly after installing, have any fixes. Is it possible that you are experiencing...
You will have to pull the unit from the dash to view the model # and Serial # either on top/bottom that will have a sticker and usually a wiring...
I have a Sony xav ax5000 that won’t come on when plugged into the truck harness. I have tested it on a 12 volt battery and it will come on that...
08Accord
08Accord
boca raton, fl
>>SQL<<
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
