Sony xav ax firmware upgrade
  • 2
User1987
Hello there people!
Ive recently purchased a car and it came with a sony xav ax headset. It could be an ax3000 or ax3200.
Im wanting to upgrade its firmware to resolve the usb android auto crashing randomly issue.
I want to make sure i download the correct firmware for it, i just dont know the model number without pulling it out from the dash. Is there a way i can find it through the system? I cant seem to find it.
Thanks in advance.
Hello there people!
Thanks in advance.
You will have to pull the unit from the dash to view the model # and Serial # either on top/bottom that will have a sticker and usually a wiring diagram as well, if there is not a model # on the Face of the unit of which should be on there unless it has worn off
That looks like it can work for backup cam for sure, thanks
931
Did the articles on issues with this unit not getting audio directly after installing, have any fixes. Is it possible that you are experiencing...
I have a Sony xav ax5000 that won’t come on when plugged into the truck harness. I have tested it on a 12 volt battery and it will come on that...
726
User1987
User1987
Australia
audiobaun
    May 18, 2024
    May 16, 2024
