Sound from sub when cd's loading
  • 4
PESteele
I wang on an 8 in a van
3,463
annapolis
whenever i put a cd in i can hear clunking from my subs. Also i still got a little static in the speakers. I tried regrounding the hu but when i disconnected the ground wire the unit still turned on. I dont understand. Could this have something to do with the fact that there is no ground wire on the factory harness?
i check all connections and the hu ground is run straight to the battery. Any idea how it could still play without it grounded?
The vehicles chasis IS the ground. A chasis point that provides the least amount of resistance is your best possible ground.
The larger the gauge wire the less resistance. The chasis is equivalant to a VERYlarge gauge wire. The ground terminal on the battery is limited to the wire connected to the chasis and that part of the chasis.
This is why we don't hook the NEG of our amps to the battery and seek a proper chasis point.
Your CD player simply has a very bad ground. Find a good spot in the dash with a screw and attach to that. Make sure all the paint is scraped away to bare metal. Paint prevents a good connection.
I have a 2011 Yukon XL slt with the factory Bose system that has rear overhead dvd and rear radio mounted on the back of the center console as...
Just got off the phone with Matt, that box isnt going to work, but ill put this out there..... https://www.soundoffaudio.com/ Anyone in south...
23
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
PESteele
PESteele
annapolis
GlasSman#1
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
