Sound stream human reign
  • 5
ray60218
Sound stream human reign hru.4
Open to all trades
RMS Power Rating:
4 ohms: 140 watts x 4 chan.
2 ohms: 240 watts x 4 chan.
Bridged, 4 ohms: 480 watts x 2 chan.
MOSFET power supply
LED power and protection indicators
Hawkins Bass Boost (0-9 dB @ 70 Hz)
STACT (Stabilized Apex Current Technology) reduces power supply stress by 50%
4-Channel operation
IDI (Intelligent Distress Indicator) provides visual indication of amplifier protection status
RUBI (Rapid-Use Branched Impulse) proprietary power supply technology
Preamp RCA outputs
Harmonic bass alignment for a cleaner and sharp bass equalization
Triple darlington output circuitry
Drive delay II eliminates turn on/off pops
4-Way protection circuitry (DC, thermal, short, and impedance)
Selectable balanced inputs for enhanced level of noise reduction
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Chrome-plated RCA level inputs
Chrome-plated screw terminals
Variable high-pass filter (50-500 Hz, 12 dB/octave)
Variable low-pass filter (40-160 Hz, 24 dB/octave)
Subsonic Filter (13-30 Hz, 12 dB/octave)
Frequency response: 10-40,000 Hz
THD (Total Harmonic Distortion): 0.005%
Signal-to-noise ratio: 105dB
Dimensions: 22-1/8"L x 11-1/8"W x 2-3/4H
4-gauge power and ground wiring is required for installation.
That xenon is about the same size. I already have another 4 channel smaller footprint
Looking for a good 15 maybe some 8's or a good mono amp I can add cash depending on the trade
Sound stream human reign hru.4Open to all trades
RMS Power Rating:
MOSFET power supply
4-Channel operation
Preamp RCA outputs
Did you get rid of the amp //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Just got off the phone with Matt, that box isnt going to work, but ill put this out there..... https://www.soundoffaudio.com/ Anyone in south...
23
918
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
910
Marine speakers would be Ideal as stated and Coax. Polks would work very well. First choice of mine would be...
422
ray60218
ray60218
Phoenix,AZ
Louisiana_CRX
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
