Soundqubed Q4-120 4 Channel amp *MINT*
  • 2
blazian87
Soundqubed Q4-120
MINT CONDITION practically flawless. No remote bass knob included. Don't get this confused with current version Soundqubed Q4-90, this amp does more power! High Power CLASS A/B Output 120w @ 4 ohms. They don't make it like this anymore!
Specifications
Model Q4-120
Dimensions 15.75" x 9"
Input Sensitivity 8V~0.2V
Low Pass Filter 50Hz ~ 5kHz
High Pass Filter 20Hz ~ 5kHz
Crossover HPF/FULL/LP-BP
Signal to Noise Ratio 105dB
Damping Factor 200
Bass Boost @45Hz 0~18dB
External Fuse Rating 40A x 2 pcs
4 ohm power @ 14V 120Wx4
2 ohm power @ 14V 170Wx4
4 ohm mono power @ 14V 340Wx2
Power and Ground Inputs 4ga
200 + shipping or local pickup
Let me know your zip code and I'll give you a shipping quote.
Looking to buy 1 Soundqubed hdc4 15” basket/ frame with gasket.
6
174
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
624
blazian87
blazian87
Los Angeles, CA
blazian87
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
