Soundqubed speakers
  • 2
nyoc
Does anyone know if the Soundqubed QP-TH25 tweeter and the QP-MR8 midrange can handle more than rated? I'm hoping to put a pair of each on a 4 channel Taramps bridged. But all the amps I've seen are either under power or over. I would like to get the most potential out of the speakers.
If you want your speakers to last, id recommend to stay within the RMS limitations for that speaker.Generally a little bit larger amplifier/ Head room for speakers and subs are great to keep the amplifier running cooler and lasting longer as well and can be adjusted just fine to work well.
Looking to buy 1 Soundqubed hdc4 15” basket/ frame with gasket.
If the JBLs have tweeters built in, disconnect two of the tweeters and the 4 Ohm tweeters will be their replacement. Then connect one combo on the...
253
nyoc
nyoc
Toledo, OH
audiobaun
