Soundstream Rub1.2500
Soundstream Rubicon Series Monoblock Class D Car Amplifier
RMS power Rating:
4 ohms: 1000 watts x 1 chan.
2 ohms: 1700 watts x 1 chan.
1 ohm: 2500 watts x 1 chan.
MOSFET power supply
Remote gain control included
Midnight blue finish w/ brushed accents
LED protection indicator will be illuminated when the amp has gone into a self preservation mode
Twin Stack Technology TM (strap amps together for double power)
Tri-Mode Capable
Three-Way Protection Circuitry (Thermal, Short, Impedance)
SMT built in cooling fan
Monoblock channel operation
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Chrome-plated rca level inputs
Chrome-plated screw terminals
Variable low-pass filter (50-150 Hz @ 12dB)
Subsonic Filter (10-40 Hz @ 12dB)
Bass Boost: 0-18 dB @ 45 Hz
Damping factor: >250
Signal-to-noise ratio: 105 dB
THD (Total harmonic distortion): 0.5%
Frequency response: 15-150 Hz
Dimensions: 22-13/16"L x 8"W x 2-3/8"H
4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
1-year Manufacturer's warranty
Works. 7/10 Cosmetic for some small scratches and marks and some major ones near the speaker terminals. I give it a 9.5/10 mechanical and here's why; both fans are loud and although if you knew how to replace them, should probably do so. If not, shouldn't matter. The amp does get hot and will cut off. It's happened to me twice. However, when I took the back plate off and bumped, it got warm but never cut off. I drove 6 hours from MD to NY bumping LOUD on and off and it didn't cut out at all, same with the drive back. I have since put the back plate back on and although it got hot, has not cut out on me since. It still works 100%.
$185 shipped firm
USPS or FedEx
RMS power Rating:
MOSFET power supply
Tri-Mode Capable
$185 shipped firm
USPS or FedEx
