Soundstream Rubicon 4.600 - $100 shipped
  • 4
avs20
Frisco, TX
Soundstream Rubicon 4.600 - Light scratches on top of heatsink due to mounting under seat
Rubicon Series 4-Channel Class AB Car Amplifier
RMS Power Rating:
4 ohms: 100 watts x 4 chan.
2 ohms: 150 watts x 4 chan.
Bridged, 4 ohms: 300 watts x 2 chan.
MOSFET PWM power supply
Platinum 4 AWG power block
Midnight blue finish with brushed accents
Selectable bass boost (0, 6, 12 dB at 50 Hz)
4/2-Channel operation
Speaker-level inputs
High and low level inputs
IDI (Intelligent Distress Indicator) for thermal, short, and impedance protection
Turn on/off delay
Heavy duty aluminum alloy heatsink for heat dissipation
Tri-mode capable
Nickel-Plated RCA level inputs
Nickel-Plated screw terminals
Infinitely variable crossovers with multipliers
Variable high-pass filter (15-4000 Hz, 24 dB/octave)
Variable low-pass filter (50-4,000 Hz, 24 dB/octave)
Frequency response: 10-35,000 Hz
Signal-to-Noise Ratio: 105dB
THD (Total Harmonic Distortion): 0.02%
Damping Factor: >250
Signal Voltage Range: 200mV - 6V
Power Voltage Range: 11V - 16V
Dimensions: 15-3/8"L x 8"W x 2"H
$100 shipped
Great price. I would recommend this amp to someone on a budget.
I got it's little brother so they're good budget little 4 ch amps.
It was a great amp...it was just taking up too much space where I had it mounted, so I had to downsize lol
I see.
Yeah it is quite big for it's size.
You have any gut shots? Kinda curious of the insides of it....I'm willing to bet the components inside are spread apart which wouold explain the bigness.
This is from another site..but here are the gut pics they had:
LOL...just realized you even replied in that thread, so technically you've seen that pic... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Item(s) for Sale: Soundstream Rubicon 4.600 - Light scratches on top of heatsink due to mounting under seat
RMS Power Rating:
Turn on/off delay
Tri-mode capable
$100 shipped
Still available
Mine connected just fine, but I liked the onboard menu better and deleted the app.
45
5K
Very true statement here. Can also possibly damage the subs if not used properly,and may even cook an amplifier in the process possibly. It may be...
Hello I have the soundstream bx 108z and just recently the remote wier came out of the power connector so I put it back in and then noticed that...
avs20
avs20
Frisco, TX
avs20
