Soundstream S10 XTREME build 40k + watts!
any place around here locally that sells it? I'm going to stay away from the aerosol version, I've had that screw up stuff before, I mean getting it on things that you didn't want stripped.
You can do a shitton to these 4.3's to scavenge power out of them. They are just a 350 with 2 pistons removed from them. A little head work goes a long way
no room for v8 swap when im adding 2 more alts.
I was thinking of camming it but I hate the sound they make (like its going to choke out in idle)
its getting new headers, sparkplug wires, spark plugs, gaskets and a few other things.
looks very promising. how long you estimating till shes done?
Well it should be back in driving mode by mid march, this painting is seriously taking 100000 times longer than I thought.. I'll probably have the full system running for sure by slamology - that's when I'm making the debut. It was supposed to be SBN, but there's just no time and I refuse to cut corners with the underbody for just 1 show.
good man
well finally started painting, hopefully I can get these done overnight. I hate dry times... I'm literally watching paint dry //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
In all there's going to be 4 coats of paint,
2 coats of POR-15 silver, and 2 coats of POR-15 engine enamel (aluminum)
Por-15 is supposed to go on very thin, so if it looks like I missed a couple spots, its because they'll be covered better with the next coat.
Kinda fell asleep while waiting for the paint to dry, but the heads are now ready for enamel, and I also put a coat on my front springs.
The springs will be top coated with Flex Cote red //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Mine connected just fine, but I liked the onboard menu better and deleted the app.
45
5K
Very true statement here. Can also possibly damage the subs if not used properly,and may even cook an amplifier in the process possibly. It may be...
Hello I have the soundstream bx 108z and just recently the remote wier came out of the power connector so I put it back in and then noticed that...
Farmacist
Soundstream Elite
Farmacist
Detroit, MI
Mr. Slate
