SOLD Soundstream USA 305 5 CHANNEL AMPLIFIER OLD SCHOOL SQ
  • 1
johnjv29
I have a Oldschool Soundstream USA305 5 channel amp that is in good condition for its age and has a few scratches.This amp works excellent and sounds even better!I received it on trade from a friend and really didnt need it so its up for sale.He was running 3 8w3's off the sub channel and I was amazingly surprised on the power this amp puts out.This amp is definately underrated and has excellent sound quality!
If you have any questions just ask..
Specs:
SPECIFICATIONS
POWER OUTPUT
CROSSOVER SPECIFICATIONS
High Pass: 12 dB/octave, factory set at 150 Hz (non-variable)
Low Pass: 24 dB/octave, factory set at 75 Hz (Variable by S.I.P.)
(800 Hz "bypass" S.I.P. included)
DIMENSIONS
USA•305: 14-1/4” W x 8-3/16” D x 2-3/16” H
SERVICE
Your Soundstream amplifier is protected by a limited warranty. Please read
the enclosed warranty card.
THD
Signal to Noise > 90 dB
Frequency Response 20 Hz to 20 kHz +/- 0.5 dB
Stereo Separation > 90 dB
Damping > 200
Input Sensitivity 100 mV - 2.5 V
Input Impedance 12 k ohms
USA•305
Power at 4 ohms 35w x 4 +
100w x 1
Power at 2 ohms 60w x 4 +
160w x 1
Bridged power at 4 ohms 120w x 2
Mine connected just fine, but I liked the onboard menu better and deleted the app.
45
5K
Very true statement here. Can also possibly damage the subs if not used properly,and may even cook an amplifier in the process possibly. It may be...
Hello I have the soundstream bx 108z and just recently the remote wier came out of the power connector so I put it back in and then noticed that...
johnjv29
johnjv29
kentwood mi
johnjv29
