speaker wire size
  • 4
I'm running 12 gauge x 4 in each sub. 2 12s wired to 2500w @ 1ohm.
I had a hard time understanding the electrical on speaker output.
Do amps put out AC voltage?
How do I calculate / measure how much voltage and current my amp puts out?
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
829
So u know the individual slots on the ISO connectors and where they go? 12 volt red is accessories. etc. Red wire goes to the amplifier...
8
Ppl love their Cruze Often it’s increasing the turbo size, changing the suspension from stock being fe1-3 to fe5, sway bar and links then brakes...
11
At 100 watts and such short runs, you’d have no perceivable difference between 12, 14, or 16 gauge speaker wire, OFC or CCA, nor worry about...
10
brice15s
CarAudio.com Recruit
brice15s
Virginia
Bass Addict
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
