UNDERGROUND_BUM 10+ year member
ok so i installed my polk momos with an Orion Cobalt CO300.2 to power them. and i get the most annoying loud static/ buz when the head unit is on pause and at a high volume ( when car is on and off) it is less noticeable when music is playing. Its coming out of the momos that are connected to the amp and the rear fill connected to the headunit. the head unit rcas are grounded out, rcas are not ran on the same side as power, headunit has a solid ground, and am pretty sure the component amp has a solid ground. what else could i do? would a ground loop isolater work?
