Speakers cut in and out
  • 3
Cyoung81
CarAudio.com Newbie
So I have a 2003 Honda Accord coupe, I’ve got 6.5 cresendos in each door everything else is stock mids and high wise, I have 1 level 3 dc 15’, but I just bought a brand new Rockford 4 channel 500 watt mids and highs amp, I’ve got everything hooked up fine but when I turn my speakers up it’ll go to the rear 6x9’s and will cut in and out in the door, so I unplugged them and now when I turn them up just my tweeters play. Before I put the 6.5s back in they all played and sounded great, could anyone please give me some ideas as to what it could be please.
My head unit is a kenwood kdcbt500, and I mean that the only after market speakers I have are the cresendos and no I ran all new speaker wire from the amp to each door. And they’re 4 ohm
Okay so stock tweeters. Possible you have a short in the speaker wiring somewhere. I would pull the speakers out of the doors and hook them directly to the amp with short speaker wire. Turn it up and see if it still does it.
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
296
If the JBLs have tweeters built in, disconnect two of the tweeters and the 4 Ohm tweeters will be their replacement. Then connect one combo on the...
246
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
200
Cyoung81
CarAudio.com Newbie
Cyoung81
Greenville, SC
subzero
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
