SPL-Lab USA- Taramp's T800.1 2ohm Testing
  • 2
shizzzon
I am who you think I am
1,294
KY
We are providing test results performed by us of the Taramp's T-800.1 2ohm model.
We are using our professional Next-USB System with Level 3 AC/DC 1200A TH HE Sensor for power output measuring and our Level 2 AC/DC 400A Sensor for power input measuring.
We are using our own contracted import company - JFA Eletronicos for regulated 115/220v AC to DC Power Supply adjustable from 12.8-14.4vDC.
We are using Centech Infrared Temperature gun for monitoring ambient and Amplifier temperature.
We are using 8 1,000w Resistive banks mounted to Steel bars for output load and heat dissipation.
We are using SPL-Lab Software v2.6.10 in both Power and RTA mode.
Amplifier rated output-
12.6v 78F 1KHz 8%THD Maximum output-
2ohm- 800w
4ohm- 456w
Our Test Results-
(Because we provide more test data than anyone else, it will be impossible to accurately compare our data with another tester without knowing all of their values as well.)
QoSFRRTAT- ("cause-for-tat")
Quality of Signal Frequency Response Real Time Analyzing Test
This tests the FR amplitude curve by measuring the signal amplitude WITH a fixed load on it that is allowed to receive variables during test such as increase in temperature, etc that would likely happen in real world.
8ohm Test ( We take LONG break intervals between each ohm load test so please try not to post replies before we complete 2 more posts completing the rest of the Ohm load testing.
It could be hours or days.. )
Ambient Environment- 71.4F
29Hz
12.8vDC
338wDC
224wAC
7.4ohm
1.5%THD
0.94PF
92.3F
Efficiency- 66.3%
29Hz
12.8vDC
472wDC
327wAC
7.6ohm
10.2%THD
0.96PF
90.8F
Efficiency- 69.3%
100Hz
12.8vDC
336wDC
219wAC
7.5ohm
1.1%THD
0.94PF
93.2F
Efficiency- 65.2%
100Hz
12.8vDC
475wDC
331wAC
7.5ohm
4.2%THD
0.96PF
90.8F
Efficiency- 69.7%
1000Hz
12.8vDC
345wDC
211wAC
7.9ohm
1.5%THD
0.93PF
93.6F
Efficiency- 61.2%
1000Hz
12.8vDC
489wDC
304wAC
8.1ohm
4.8%THD
0.94PF
86.9F
Efficiency- 62.2%
30Hz
14.3vDC
438wDC
271wAC
7.7ohm
1.1%THD
0.94PF
96.4F
Efficiency- 61.9%
30Hz
14.3vDC
586wDC
409wAC
7.6ohm
5.3%THD
0.95PF
98.9F
Efficiency- 69.8%
100Hz
14.3vDC
466wDC
290wAC
7.6ohm
1.2%THD
0.94PF
98.0F
Efficiency- 62.2%
100Hz
14.3vDC
599wDC
409wAC
7.7ohm
4.3%THD
0.96PF
98.9F
Efficiency- 68.3%
1000Hz
14.4vDC
510wDC
256wAC
8.2ohm
1.1%THD
0.94PF
98.0F
Efficiency- 50.2%
1000Hz
14.3vDC
611wDC
387wAC
8.5ohm
13.3%THD
0.96PF
98.6F
Efficiency- 63.3%
We keep documented proof of all obtained values by freezing the software and taking a picture of the results before next test.
4ohm Test
Ambient Environment- 70.7F
31Hz
12.8vDC
495wDC
309wAC
3.5ohm
1.0%THD
0.97PF
95.9F
Efficiency- 62.4%
31Hz
12.8vDC
824wDC
562wAC
3.7ohm
17.5%THD
1.00PF
95.6F
Efficiency- 68.2%
31Hz
14.3vDC
614wDC
356wAC
3.8ohm
1.0%THD
1.00PF
98.6F
Efficiency- 58.0%
31Hz
14.3vDC
1040wDC
720wAC
3.6ohm
5.3%THD
0.97PF
82.1F
Efficiency- 69.2%
100Hz
12.8vDC
598wDC
384wAC
3.7ohm
1.2%THD
1.00PF
96.5F
Efficiency- 64.2%
100Hz
12.8vDC
859wDC
574wAC
3.6ohm
5.0%THD
0.97PF
95.0F
Efficiency- 66.8%
100Hz
14.3vDC
816wDC
521wAC
3.7ohm
1.3%THD
1.00PF
98.0F
Efficiency- 63.8%
100Hz
14.3vDC
1053wDC
745wAC
3.5ohm
12.1%THD
0.96PF
84.8F
Efficiency- 70.8%
2ohm test.
Ambient Temperature- 71.3F
31Hz
14.3vDC dropping to 14.00vDC
1109wDC
599wAC
1.9ohm
1.1%THD
0.99PF
92.3F
Efficiency- 54.00%
31Hz
14.3vDC dropping to 13.47vDC
1443wDC
871wAC
1.8ohm
4.9%THD
0.99PF
88.7F
Efficiency- 60.4%
29Hz
12.8vDC
1251wDC
784wAC
1.8ohm
6.0%THD
0.99PF
77.0F
Efficiency- 62.7%
100Hz
12.8vDC
1291wDC
775wAC
1.9ohm
9.3%THD
1.00PF
82.7F
Efficiency- 60.0%
100Hz
14.3vDC dropping to 13.97vDC
1161wDC
674wAC
1.9ohm
1.5%THD
1.00PF
93.2F
Efficiency- 58.1%
100Hz
14.3vDC dropping to 13.17vDC
1383wDC
867wAC
1.9ohm
7.3%THD
1.00PF
86.3F
Efficiency- 62.7%
Protection System- While supplying shorted output and low impedance protection, the circuit itself protects against excessive output and Strict impedance protection.
We tested 2ohm load dropping below 2ohm (around 1.7ohm) on less than 100w and within 20 seconds, it went into protect.
Testing frequencies below 20hz repeatedly at 0dB results in excessive output protection but above 20Hz, does not effect it.
Due to the natural roll off of the Rail to produce clean output in the amplifier in the lower frequencies, we do NOT recommend it for subwoofer use.
You may lose some output power in the subwoofer range and more importantly, the amplifier begins to clip at a fixed volume point when dropping into the subwoofer range from a lower midbass range.
This amplifier should be used for midbass, midrange and tweeter use.
Maximum output levels achieved-
871w 13.5vDC 31Hz 1.8ohm
867w 13.2vDC 100Hz 1.9ohm
784w 12.8vDC 29Hz 1.8ohm
745w 14.3vDC 100Hz 3.5ohm
720w 14.3vDC 31Hz 3.6ohm
574w 12.8vDC 100Hz 3.6ohm
409w 14.3vDC 100Hz 7.7ohm
409w 14.3vDC 30Hz 7.6ohm
387w 14.3vDC 1000Hz 8.5ohm
Tested Clean output for 100Hz-
7.5ohm 12.8vDC 219w
7.6ohm 14.3vDC 290w
3.7ohm 12.8vDC 384w
3.7ohm 14.3vDC 521w
1.9ohm 13.97vDC 674w
This is the end of our testing with this product.
Efficiency hovered in the 60s pretty much throughout the whole test.
THD, the amplifier is rated at 8%THD so it was imperative for us to test it's output on varying THD to get more data from it.
shizzzon
shizzzon
KY
shizzzon
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
