SPL-Lab USA- VE Audio AB-150.2 Testing
  • 1
shizzzon
I am who you think I am
1,294
KY
We are providing test results performed by us of the VE Audio AB-150.2 2ohm model.
We are using our professional Next-USB System with Level 3 AC/DC 1200A TH HE Sensor for power output measuring and our Level 2 AC/DC 400A Sensor for power input measuring.
We are using our own contracted import company - JFA Eletronicos for regulated 115/220v AC to DC Power Supply adjustable from 12.8-14.4vDC.
We are using Centech Infrared Temperature gun for monitoring ambient and Amplifier temperature.
We are using 8 1,000w Resistive banks mounted to Steel bars for output load and heat dissipation.
We are using SPL-Lab Software v2.6.10 in both Power and RTA mode.
Amplifier rated output-
150w x 2 4Ω 14.4v 1%THD
240w x 2 2Ω 14.4v 1%THD
480w x 1 4Ω 14.4v 1%THD
Our Test Results-
(Because we provide more test data than anyone else, it will be impossible to accurately compare our data with another tester without knowing all of their values as well.)
QoSFRRTAT- ("cause-for-tat")
Quality of Signal Frequency Response Real Time Analyzing Test
This tests the FR amplitude curve by measuring the signal amplitude WITH a fixed load on it that is allowed to receive variables during test such as increase in temperature, etc that would likely happen in real world.
Ambient Temperature- 75.8F
2ohm Stereo
29Hz
14.3vDC dropping to 14.01vDC
1069wDC
197x2wAC
1.85ohm
1.0%THD
0.97PF
86.6F
Efficiency- 36.9%
29Hz
14.3vDC dropping to 13.91vDC
1301wDC
274x2wAC
1.8ohm
3.7%THD
1.00PF
77.9F
Efficiency- 42.0%
100Hz
14.3vDC dropping to 14.03vDC
1059wDC
206x2wAC
1.85ohm
1.0%THD
0.98PF
86.3F
Efficiency- 38.9%
100Hz
14.3vDC
1317wDC
281x2wAC
1.85ohm
4.6%THD
1.00PF
80.6F
Efficiency- 42.7%
1000Hz
1173wDC
233x2wAC
1.75ohm
1.4%THD
0.97PF
83.9F
Efficiency- 39.7%
1000Hz
14.3vDC
1309wDC
297x2wAC
1.75ohm
9.3%THD
0.98PF
80.9F
Efficiency- 45.3%
5000Hz
14.3vDC dropping to 13.98vDC
1180wDC
250x2wAC
2.05ohm
0.1%THD
0.92PF
81.3F
Efficiency- 42.3%
4ohm stereo-
29Hz
14.3vDC
526wDC
133x2wAC
4.0ohm
1.3%THD
0.94PF
86.0F
Efficiency- 50.4%
29Hz
14.3vDC
606wDC
165x2wAC
4.0ohm
10.6%THD
0.95PF
86.3F
Efficiency- 54.5%
100Hz
14.3vDC
532wDC
137x2wAC
3.95ohm
1.4%THD
0.94PF
86.0F
Efficiency- 51.5%
100Hz
14.3vDC
610wDC
168x2wAC
4.0ohm
3.7%THD
0.95PF
86.0F
Efficiency- 55.2%
1000Hz
14.3vDC
509wDC
131x2wAC
4.0ohm
1.4%THD
0.94PF
86.3F
Efficiency- 51.5%
1000Hz
14.3vDC
591wDC
166x2wAC
4.1ohm
6.2%THD
0.95PF
86.0F
Efficiency- 56.0%
5000Hz
14.3vDC
545wDC
162x2wAC
4.1ohm
0.1%THD
0.93PF
86.6F
Efficiency- 59.4%
Results-
One thing that greatly sticks out about this amplifier is the higher frequency range exhibits virtually no distortion.
We did several burst tests at 5 and 10KHz with everything maxed out and could not get a distortion reading that is worth even noting.
While this is a full range Class AB amplifier, using it solely for horns, tweeters and super tweeters would make a great product of choice to virtually guarantee a full clean amplification.
Using it for everything else, it has the ability to burst into a higher THD resulting in wider dynamic range but it's only really measurable on max settings. The amplifier tends to stay clean throughout the spectrum as noted in video above.
shizzzon
shizzzon
KY
shizzzon
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
