Spring installation prices?
mackin
srsly
1,249
Plymouth, MN
I'm considering buying lowering springs for my Millenia S. (there arent coilovers offered for my car, otherwise i'd do that)
I've never had any suspension work done before, so i'm curious what kinds of installation prices I should be expecting for lowering springs. I don't need new struts or anything else, just springs installed.
ballpark figures would be appreciated!
thanks!
Pic for clicks:
*windows tinted since picture was taken
english? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
edit: i've been on millenia forums and i've been told it is unnecessary to replace shocks/struts unless they are already very worn.
You should be able to get springs installed for under $200. Don't forget about an alignment though. I'd go to an alignment shop and see if they'll do it all at once. The install and the alignment. I know a few local places for me that do that.
Make sure you get a spring compressor.
I changed mine in my civic and it was pretty straight forward, and i knew nothing at that time.
It prolly wouldnt be much for a local mechanic to do it....100 bucks tops
to have a shop do it, you can expect atleast an hour a corner. Probably 50 for so and hour so around 200 + an alignment which is another 50 or so. Id guestimate 250+
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Hi, I have a 2015 Mercedes W205 with the standard audio 20 system, which is terrible to be honest. In my W204 it was really good even though I...
Generally you can still use the High Level inputs on most any amplifier to get it installed off the HU speaker wiring. Its a bit old school way of...
10
mackin
srsly
mackin
Plymouth, MN
davidfre21
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
