Square vs Round Subwoofers
CpsChase
Square Subwoofers vs. Round Subwoofers
The shape of a subwoofer on the surface might appear to just be based on pure looks, but different shapes add unique beauty to audio sounds including hexagons, oval, and square. There is a ton more than just the look on the outside of the subwoofer than just the shape. Many audible factors change by the variable of the shape you want.
Volume and Surface Area
Subwoofer volume is calculated by the sound pressure created by the speaker. Cones with a bigger surface area will be able to push more air to move thus causing more powerful vibrations produced. When you compare a 10 inch round subwoofer to a 10 inch square subwoofer, the square will sound louder even though they are classified as 10 inches. This is all due to square designs having 4 corners to the cone's surface area. With the increase of surface area this translates to a larger volume of air and also more addition vibration. However on the downside, with the extra corners on a square subwoofer there's a chance of sound wave distortion. For round subwoofers, having no corners generates better sound quality with a faster response to the sound being played.
Power Efficiency
As mentioned previously, we've established that air displacement determines how loud your sub can actually get. For example, a round subwoofer will have more excursion than a square subwoofer at this same rate of time to produce the same amount of bass. So in conclusion square speakers are more power efficient than round speakers since they don't have to move as much of a distance, which will save more power.
Frequencies
Scientifically speaking, larger subwoofers can produce lower frequencies much more accurately. But as the size goes up it it harder to replicate the higher frequencies, decreasing the sound quality significantly. All of this means if you match a 12 inch square subwoofer with a 12 inch round subwoofer, round subwoofers will be able to replicate the higher frequencies due to the smaller surface area of the cone.
Cost Comparison
Without any doubt we know that round subwoofers are the most popular choice for most car owners. In addition to being cheaper than a lot of square subwoofers, they produce a higher quality sound. Another bonus is that they are more readily available, there is a larger selection of round subwoofers.
Looks and Space
It's hard to believe but a few people choose their subwoofers absolutely based on looks. Though it really isn't a very shrewd decision to go with looks alone, you can ultimately decide on any shape you want. But before you purchase! A big factor to consider is available space for your subwoofer enclosure. If you are purchasing dual subs into one single enclosure, round subs will take up more space. The circular round design technically waste space since there aren't any corners to align.
Decision Time
With all of these factors about shape our list continues with response, house, materials used, and size. All shapes have their own pros and cons, but in the end it simply comes down to what you want from your car's subwoofer. If you have the extra cash available, and you have a little less space available, then a square subwoofer is your go to. On the other hand if you are wanting to add another dimension to your sound system with a smaller budget limit you'll be best to go with a round subwoofer.
Thanks for reading! Article from Mobile Audio Shop Car Audio Shop - Mobile Audio Shop Premium Car Audio Store
Yeah that's a bit off
Output is a combination of cone area and excursion. Displacement.
A square sub that only has 10mm of throw will get killed by a round one with 20mm of throw.
Square subs also require more airspace then the round counter part.
Larger subs will be more efficient low bass to high bass. Smaller subs will be less efficient.
They both will play sub bass or they wouldn't be subs
Yeah this is mostly bull ****.
Power Efficiency
Frequencies
Cost Comparison
Looks and Space
Decision Time
guess you never heard a 6.5 inch sub play 17hz accurately and 18 inch subwoofer play heavy metal.... its the same as stating bigger subs play deeper and smaller subs play punchier, thats just a bonafide myth perpetuated by noobs thats been debunked left and right in the competition lanes.
The main factor that completely determines the whole install thats WAAAAY more important than all this bullsh*t is that square subs require much larger enclosures because a square 12 is closer to a 15 and needs 2.5 to 3 cubic feet rather than 2 cubic feet like a normal 12.
That statement about having less space and going with a square sub is the worse piece of advice on here. This whole post has soo much misinformation is nauseating.
Oh? Do you want proof?
Craig Butler, record holding SPL competitor. Uses 18s and burps at 60hz.
Gary Biggs, the now co-owner of Audiofrog held a long time SQ championship using solo X 18s and L7s up front as mid bass.
Scott Bulwalda uses 6.5in subs and he is the current highest scoring SQ car. We are judged 20hz to 20,000hz
You can look at kickers site at the box specs. They give the bare minimum it will make some kind of bass in and the maximum which is for performance.
Yeah Sonic is great.
You're comparing 2 different size subwoofers. A 10 inch square WILL provide more bass than a 10 inch rounded, a 12 inch square WILL provide more bass than a 12 inch rounded.
Smaller subs like an 8 inch will hit lower notes more efficiently.
And yeah, no **** they both play sub bass:laugh: that's why they're called subwoofers
You should go here. You will leave with a different understanding. You might turn into one of us forum guys.
You know, the guys that actually know how it really works and not trying to sell something to a newb.
It will only provide more bass if it has more displacement. Most squares are lacking excursion. Which is part of the equation.
Don't believe me?
Try it yourself. Put in the numbers for a 12 L7 and a 12in um... Fi Q
Closed Subwoofer Box Equations Formulas Design Calculator Vd Maximum Air Volume Displaced By Cone Excursion
---------- Post added at 07:53 PM ---------- Previous post was at 07:52 PM ----------
did you post a link?
Sorry here. One of the biggest events in the country.
Aggieland Invitational SQL Texas – MECA – Mobile Electronics Competition Association
This information was collected from http://www.SonicElectronix.com. They kinda know what they're doing in my opinion.I think I trust their judgement over some guy on a car audio forum, but thanks for your input.
Think Jeffdachef took a hit on this one. He's the next TaylorFade of car audio on here. You def don't wanna mess with him. I would trust him more than Sonic electronix. Experience/hands on is key. Anybody can do write ups and not provide pics/vids/proof or even a review.
What’s up y’all, new to this place… today actually… Idk, i guess if I’m gunna ask for help wit this mess, now is prob the time…. First things...
Once you get the tools and basics down it's not too bad. The turn table is a must imo.
https://audioassemble.com/round-vs-oval-speakers/#:~:text=If%20you%20opt%20for%20a,it%20is%20small%20in%20size. This is what I found with a...
Like @maylar said, delay the turn on to the amplifier only. 3 to 5 seconds should take care of it.
8
364
CpsChase
CpsChase
Houston, TX
BOOMINGRANDPA
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
