Stage 2 front comp / rear coax options or stick w/ budget option
  • 1
powerlifter405
CarAudio.com Exclusive
Hi again,
I appreciate all the suggestions and have my budget minded options down to 1 or 2 choices.
I have noticed CDT, Image Dynamics and a few others being mentioned as slightly better choices.
Fwiw a set of Infinity Reference front comp 6x9/rear coax 6.5's for under $170 is hard to beat. I've had reference series before and I've been happy w/ them. https://www.amazon.com/gp/product/B07N94MBY5/?tag=caraudiocom-20 The kappas are still over $300 for a set of front/rears and stand alone kappa comps are still mid $250ish. I'm either going all out budget reference or I'll bump up a bit for a "stage 2" option if not much more.
I do have a Kicker Key 200.4. 50watts rmsx4 W/ DSP
W/ the DSP will I notice any reasonable improvement if I decide to spend a few more bucks??? I'll probably use a ford/OEM rear behind the seat sub. I recently did a 800 mile trip w/ two very large dogs in my F150 and loss of under seat storage cannot/will not occur. The OEM Sub box is 8" sealed, I'll run a Kicker Key 500.1 w/ DSP and I'll grab a Kicker/RF/ID/SD type shallow that will fit but that's another thread in the next few weeks.
Should I decent to bump up my budget a hair I am finding some other options:
These are on sale at CF for $114, regularly $220! Had MBQ that were previous owner installed on a 99 SD, sounded pretty decent https://www.crutchfield.com/S-YSkB2...ef=ox_sc_act_title_2?smid=A3SFPIL4KA3KL&psc=1
ID and if you get the CTX you get $25 off. https://www.woofersetc.com/c-172-sp...-rms-id-series-component-speakers-system.html
Same cost, 1 series up https://www.woofersetc.com/c-172-sp...age-dynamics-65-component-speaker-system.html
https://www.woofersetc.com/c-172-sp...wn-audio-e-6-5cs-6-5-100w-rms-components.html
SD has their yard sale and an open box set of these for $224 https://www.woofersetc.com/c-172-sp...io-6-5-125w-rms-component-speakers-system.htm
Polk MM series https://www.amazon.com/dp/B071G8K9SK/?tag=caraudiocom-20 and a set of DB rear coax for the rears is less than $75.
The polk MM and the MB quarts has a very broad FR and should play mids pretty well w/ the amp. The MM's and the Infinity are very efficient so they'll play "loud" comparatively.
Some focal options as well
Focal ISS-690 6" x 9" 80W RMS 2-Way Integration Series Component Speakers System
At the end of the day, I'm pondering if spending an extra $50-$75 is worth it. IF I go pricier in front I'll probably drop 1 series/model for the rear coax. I'm trying to keep this budget as possible but I'll entertain a slight bump in budget IF it provides the SQ and output improvement.
TIA!!
The umm1 is just a rebadged dayton/minidsp mic. I personally have a umik2 and use a regular usbc-usbc to hook it up to my laptop and a...
8
183
Yes, time to move some stuff for sure. Have a little mini CA warehouse in the garage!
10
677
Sounds like your front stage is overpowering your sub stage/ Weak sub stage. Is this a 4dr. Sedan or a Hatchback WRX? Where do you have the sub...
22
3K
May be a weak link. Hifonics has been pretty dubious for going on 30 years now.
11
powerlifter405
powerlifter405
Ur moms place
powerlifter405
Latest topics
