Starsound ssa-4040
  • 3
SetoKaiba2
CarAudio.com Newbie
Hi everyone, i am trying to connect this amp to my factory sound system just to add an additional sub. now the factory radio does not have RCA output. i have a high to low converter but searching the internet i found that i can use the amp's high input instead. the problem is, idk how to connect the high input as there is no indication on the amp to which wire goes where. any help would be appreciated.
https://media.karousell.com/media/p...40_car_amplifier_600w_1481713933_12ec7b77.jpg
Does your car have a fancy dash that is difficult to put a aftermarket HU in? Cause it would probably be easier to just get an aftermarket HU
Does your car have a fancy dash that is difficult to put a aftermarket HU in? Cause it would probably be easier to just get an aftermarket HU]
Do you have the harness for the amp?
Yes, the original radio is connected to a in-dash screen that makes it easy to search for songs and is also used to adjust settings on the car. there is working speaker wire in the boot for the original sub but that sub is barely noticeable.
What kind of music do you listen to? I'm a fan of SSA's subs quite a bit. Everyone I designed for really liked their SSA's, and I do like their...
14
I picked up a couple 12's for my civic. Figured I would hook someone up on here. Not trying to nab business, just trying to turn it around for the...
4
999
Evils are made to order, but the lead time is VERY short.
13
From their website. Sealed: 0.8 – 1.1 cubes Ported: 1.75 – 2.1 cubes ported after displacement, 29-33hz tuning Sub Outside Diameter 12.500" Cut...
SetoKaiba2
CarAudio.com Newbie
SetoKaiba2
South Africa
SetoKaiba2
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
