Static in new speakers
  • 4
Zesiar
I recently purchased 4 new 3-way speakers for my vehicle.
As well as a 4 channel 2400w amp and a equalizer. Equalizer
worked with my sub output to 5000w amp.
When I plug my speakers into the amp and turn it on, all is fine.
But when my 4 RCA go into my equalizer I get static as well as
very low sound like dubbed out. I did a RCA to aux (2 rca plugs)
to test and no static or dubbed, sounds good.
I am ruling out any wires being ran along the power cable as my RCA
are not and my speakers work when not hooked to equalizer.
My amp is grounded good. And the speakers should not be bottoming
out or the RCA to aux would do the same right?
So is my equalizer not grounded good? Or is it just the RCA jacks on it?
Specs/Links:
RCA cable-/
http://www.amazon.com/gp/product/B00E3KWKHE?psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s01
Door speakers-/
http://www.amazon.com/gp/product/B000230LC2?psc=1&redirect=true&ref_=oh_aui_detailpage_o04_s00
4 channel amp----Hooking 2 subs to this-/
Amazon.com: Planet Audio AC2400.4 ANARCHY 2400-watts Full Range Class A/B 4 Channel 2 Ohm Stable Amplifier: Car Electronics
Mono block for my subs-/
http://www.amazon.com/gp/product/B003GSLE1M?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s01
Equalizer-/
Soundxtreme Car Audio Passive Equalizer 7 Band 1 2 DIN Pre Amp EQ Sub Crossover | eBay
Subs going to 4-channel amp-/
Amazon.com : E-10D2 - Sundown Audio 10" Dual 2-Ohm E Series Subwoofer E10D2 : Vehicle Subwoofer Systems : Car Electronics
get your money back on everything but the sub. You bought a bunch of garbage.
Hate to say it but he's right
The issue could be from any one of them the amp, speakers, and eq are flea market grade. They were built to be thrown away. It's common to see DOA components in this grade of equipment.
Iv already opted out faulty speakers and amp when I hooked
a rca to aux to the amp.
What can I do to get the equalizer to not cause static?
I recently purchased 4 new 3-way speakers for my vehicle.As well as a 4 channel 2400w amp and a equalizer. Equalizer
Specs/Links:
RCA cable-/
Amazon.com: Carwires AC4000-12 4-Channel Twisted-Pair Car Audio Cable (12 feet): Car Electronics
Door speakers-/
Equalizer-/
your equalizer isnt amplified so no noise should be in it...it just cleans up the sound from your head unit before it goes to your amp...the amplifier ...amplifies the headunits volume...if your deck never got noise before ...id go over the amps wiring...maybe a bad ground to the amp
If I don't use the head unit or equalizer and just RCA to my phone it plays fine.
Try and use the factory ground wire in the harness instead of chassis ground to see if it makes a difference
906
You need to troubleshoot. I assume you have an aftermarket HU. I'd start there by running a signal from a phone or ipod (etc) to the RCA outputs...
I was listening to music one day and after pausing it on my phone (i was using Bluetooth) there was a very present static, It has been working...
Zesiar
Zesiar
America
Zesiar
