Stetsom 4K2D Installed Finaly
  • 2
etznova
OK finally got the 4K2D installed
Previously i was running a Z1 to a 9515 at 2ohms feeding it power was a NSB90
Now i have installed two 2150 tsunami batts and still running the 9515 wired to 2ohms
now i don't have a clamp meter just a couple of volt meters.so take this info for what it is.
input voltage starting at 13.95
while setting the gain it was about a five minute period of time involving checking connetions. In the end @ 45hz was getting 120.3v voltage dropped down to 12.20v
the indepence was probably up around 5 to 6 ohms but until i get a clamp meter and another voltmeter i really won't be able to tell for sure. With the Z1 I was seeing about 60 to 80 volt AC so i have doubled the power
heres some pics.
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
I have no experience with them, but it does not look half bad for it's price. Big plus if you can set all features via cell phone. If you do pull...
  • Locked
THESE ITEMS WILL BE REMOVED FROM THIS FOR SALE THREAD ON AUG.16,2022 @9PM CT. THANKS
12
etznova
etznova
Cherry Valley, il.
dtbrown
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
